315
Add tabs afterwards
Hi, can you please outline how to achieve the following behaviour:
we want only the application tab in the ribbon visible at start, and no other ribbon tab should be selectable until the user selects something in the application tab.
I could hide the other tabs using visibility = hidden or collapsed, however, the other tabs would still be there and if I clicked on "Start" twice, the application would auto-jump to the first tab, even if it were set to hidden or collapsed. That is not what I would expect if the tab is set to collapsed.
I guess the solution would be to add the tabs afterwards, after the event (user has seleted something) has occured. How could I do so or is there a better way?
