343
Index was outside the bounds of the array.
Hi All,
i have 2 xamdatagrid and i want transfer the data from one to another one
the sender xamdatagrid "xampaxCost" has about 5 record instead the receiver"xamPaxCost_Copy" has 0 record (empty),
both are set up in this way in xaml
<Custom:XamDataGrid.FieldLayoutSettings>
<Custom:FieldLayoutSettings HighlightAlternateRecords="True" AllowAddNew="True" AutoGenerateFields="False" />
</Custom:XamDataGrid.FieldLayoutSettings>
<igDP:XamDataGrid.FieldSettings>
<igDP:FieldSettings AllowEdit="true"/>
</igDP:XamDataGrid.FieldSettings>
<Custom:XamDataGrid.FieldLayouts>
<Custom:FieldLayout>
<Custom:Field Name="Name" Label="Pax Label" Width="77">
</Custom:Field>
<Custom:CurrencyField Mask="nnnnnnnnnn.n" Name="Price" Width="70" Label="Pax Price" />
<Custom:Field Name="CODE" Width="70" Label="CODE" />
</Custom:FieldLayout>
</Custom:XamDataGrid.FieldLayouts>
and there  is a button to transfer the data with the code behind so:
for (int i = 0; i < xamPaxCost.Records.Count; i++)
(xamPaxCost_Copy.Records[i -1] as DataRecord).Cells[0].Value = (xamPaxCost.Records[i] as DataRecord).Cells[0].Value.ToString();// ERROR
(xamPaxCost_Copy.Records[i] as DataRecord).Cells[1].Value = (xamPaxCost.Records[i] as DataRecord).Cells[1].Value.ToString();
(xamPaxCost_Copy.Records[i] as DataRecord).Cells[2].Value = result.ToString();
in the first line i got the error " Index was outside the bounds of the array."
Do you have any idea how to work out this error.
Best Regards
