When I use a grid splitter to have a XamNetworkNode and other control split in a grid, the OverDetailsPane of XamNetworkNode is not showing the view correctly. Even though all the nodes are in view, the OverviewPane is showing only a portion of graph as selected region that is in view.
Attached the sample project and snapshot as a zip file.
Can anyone help in fixing this issue?
Prasad
The development issue 206355 has been fixed. The fix is available in the latest Service Release 15.1.20151.2188. You can download the Service Release by logging in our web site and then going to Account\My Keys and Downloads page.
Hello Prasad,
Thank you for reporting this behavior. This was tested in a sample project where only the XamNetworkNode and the OverveiwPane were added and the same was reproducible when the height of the main window was modified. I have logged it in our internal system with a development ID 206355 and I have created a support ticket on your behalf so you are automatically updated when a fix or other resolution are available. The support ticket number is CAS-164086-S1D2P5. You can review it at https://ko.infragistics.com/my-account/support-activity.
