I've tried asking my question here: http://ko.infragistics.com/community/forums/t/81658.aspx
But received no response there.
I'm using a nested XamDataGrid (v15.1), let's say Orders -> Order lines. On the nested grid (Order lines), if there are no records, the column headers are not displayed.
The ObservableCollection that it is bound to is initialized, but empty. That was the answer to previous question about top-level grids, but it does not seem to work.
The only workaround I've found is to add a null to the collection and later remove it when there are new records added, but that is not a clean solution and looks more like a hack.
Is there any other way to accomplish this?
Gediminas.
Thank you for your feedback.
I am very glad that my suggestion was helpful for you. If you require any further assistance on the matter, please do not hesitate to let me know.
I think the solution with hiding new record row suits our needs, since no changes in ViewModel code are required.
Thank You!
Hello Gediminas,
Thank you for your post.
I have been researching the functionality you are trying to achieve and it seems that currently our XamDataGrid control does not provide built-in the ability to display column headers when there are no records.
What I can suggest you in order to be able to achieve the functionality that you are looking for is to set the AllowAddNew property of FieldLayoutSettings for your parent or child layout to true, this way you enable the user to add records.
If you want to hide the empty record you can create style for DataRecordPresenter and by using DataTriggers you can determine whether the record is AddNew record or not - by using IsAddRecord property of DataRecordPresenter. If the record is AddNew record you can set its Height property to ‘0’.
I created short sample application based on your scenario in order to show you how you can implement this approach and achieve your requirement.
If you would like you can add 'the ability to display column headers when there are no records' as a suggestion for future implantation.
You can suggest new Product Ideas for future versions (or vote for existing ones) at http://ideas.infragistics.com.
Steps to create your idea:
Log into the Infragistics Product Ideas site at http://ideas.infragistics.com (creating a new login if needed).
Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)
Add your product idea and be sure to be specific and provide as much detail as possible.
Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
Include a link to this thread in your idea so product management will be able to look back at this case.
The benefits of submitting the product idea yourself include:
Direct communication with our product management team regarding your product idea.
Notifications whenever new information regarding your idea becomes available.
Additional benefits of the Product Idea system include:
Ability to vote on your favorite product ideas to let us know which ones are the most important to you. You will have ten votes for this and can change which ideas you are voting for at any time.
Allow you to shape the future of our products by requesting new controls and products altogether.
You and other developers can discuss existing product ideas with members of our Product Management team.
The product ideas site allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Thank you for contacting Infragistics.
