135
How to make xamdatagrid`s all cell equally by one settings?
<igDP:Field  Name="two">
          <igDP:Field.Settings>
           <igDP:FieldSettings CellValuePresenterStyle="{StaticResource MaintenanceIndicatorStyle}"
          </igDP:Field.Settings>
         </igDP:Field>
         <igDP:Field  Name="three">
         </igDP:Field>
         <igDP:Field  Name="four">
         </igDP:Field>
above, field was set respectively. How to make xamdatagrid`s all cell equally by one settings? and in code behind can be setting?
  • 2125
    I  suggest  you the following (as prerequisites):
    1.       Go to  http://ko.infragistics.com/dotnet/netadvantage/wpfdownloads.aspx page  ;
    2.    Download and  install  the  NetAdvantage for WPF 2008 Vol. 1  product ;
    There are so many  properties on the  FieldSettings class that it would be very  inconvenient  for you  to have to set  them all on every  Field object.  Let me offer  you  two possible solutions.
    Solution  1 If  an individual  Field object has no explicit value for a property on its Field settings, the value for that property resolves to  the  FieldSettings  on the  Field Layout.
    All Fields related to a particular type of data record  can therefore share the same Fields settings at the level  of their Field Layout.
    Look in  NetAdvantage for WPF xamFeatureBrowser ->xamDataGrid->Layout and Behavior-> FieldSettings Overrides sample
    In the FieldSettings  Overrides  sample  focus on the part below . I have made  some changes  to correspond to your  XAML  snippet:
                <igDP:FieldLayout Key="Category">
            <igDP:FieldLayout.FieldSettings>
                 "{StaticResource  MaintenanceIndicatorStyle}"/>
            </igDP:FieldLayout.FieldSettings>
     <igDP:FieldLayout.Fields>
       <igDP:Field Name="two"/>
       <igDP:Field Name="three"/>
       <igDP:Field Name="four"/>
     </igDP:FieldLayout.Fields>
           </igDP:FieldLayout>
          Solution 2 -  Simply create a new Style which targets the CellValuePresenter control and use the ControlTemplate to gain
               the   complete control over the visual aspect of the cells. Look in  NetAdvantage for WPF xamFeatureBrowser ->
                   xamDataGrid->Themes and Custom Styles->  Custom CellValuePresenter  Style – Advanced  sample
               to  see the implementation of the   solution .
                Best  Regards,                            Yanko
