I've followed some suggestion I've found in the net (confirmed by intellisense) for highlighting every second row in my data grid.
<igDP:FieldLayoutSettings AutoGenerateFields="False" RecordSelectorLocation="None" HighlightAlternateRecords="True" />
HOwever, this doesn't produce the expected coloring (all the cells have white background, independent of the index). Not sure how to trouble-shoot it.
Hello Konard,
I am just checking your progress on the issue that you are having.
If you require any further assistance please do not hesitate to ask
Hello Konrad,
Thank you for your post.
I have been looking into it. I created a sample application based on your scenario and I could not managed to reproduce the behavior that you have described. If you are not able to reproduce the issue with the attached sample application, would you please modify it with the functionality, that you are using, so it reproduces the issue. This way I would be able to further investigate this for you and provide you with more detailed information on this matter.
