I tried the below approach to add the comments:
http://help.infragistics.com/Help/Doc/WPF/2012.2/CLR4.0/html/IGExcelEngine_Add_a_Comment_to_a_Cell.html
I don't get any error after adding the comment. The worksheet cell's property - hasComment also returns true. But on xamspreadsheet, when i try to hover on the cell. It does not show any comment.
Do we need any further configuration or settings to make the comments view able on the xamspreadsheet.
S.
I also need to know this information, Thanks for sharing such types of informative information.
www.onedollarwebhostings.com/
I am just checking if there is anything else I can do for you.
Hello Sherry,
Thank you for your post.
I have been looking into it and it seems that the data validation rules are released from version 15.2.
As I mentioned in my previous posts about the functionality to display comments in XamSpreadsheet the best approach I can suggest you is to add this functionality as a suggestion for future implantation at:
http://ideas.infragistics.com
Thank you for choosing Infragistics.
"Thanks for the reply, but AnyValueDataValidationRule does not have visual effect. I mean, on the XamSpreadsheet i don't see any effect of using a rule for a cell. Do i need to do something more in order to show the notes or comment section on the xamspreadsheet."
In addition to above question, I also want to inform you that we are using the 15.1 version dll, as I saw that the data validation is the new feature http://ko.infragistics.com/samples/wpf/spreadsheet/data-validation.
Do it is officially released?
Hi Zhivko ,
