80
Need to add two colors ScatterLineSeries
I need to add two colors ScatterLineSeries.
From 0-x1 : Color 1
From x1-end : Color2
Any suggestions?
  • 34510
    Verified Answer
    Hi Kinsly,
    A single ScatterLineSeries can only be set to one color so if you need to show two different colors you will need two different scatter series.  I recommend that you split your data into two lists, one that goes from 0-x1 and the other goes from x1-end.  Then you can have two ScatterLineSeries in the chart, one bound to the 0-x1 list and the other bound to x1-end list.  Then set their Brush properties to the desired color for each.
