I have a maskedInput with dynamic ValueConstraint. My actual mask is : "nnnnn.nnn"
I bind Max and Min value to properties in my ViewModel.
I have smoe questions :
-How to remove unwanted 0 when the maxValue is 1. Because it's display 1.000
It occurs when the value is not a decimal, the mask add some 0 after
-Display 0.x is my range is 0 to 0.9 and not .2 for example.
Could you help me to achieve these requirements ?
Regards
Hi teamtim,
The masked input control has a Format property. Set this to "G". Also make sure that the ValueType on the masked input matches the type you are binding to. This should take care of your requirements.
