80
How to Display XamSliderNumericThumb Value?
I want to display XamSliderNumericThumb value (Not the TickMarks). How Can I do that?
<ig:XamNumericRangeSlider Grid.Row="0" Name="XamDateTimeRangeSlider1" MinValue="{Binding Path=VoltageRangeSlider.Min}" MaxValue="{Binding Path=VoltageRangeSlider.Max}">
<ig:XamNumericRangeSlider.TickMarks>
<ig:SliderTickMarks TickMarksFrequency="100" UseFrequency="True" />
<ig:SliderTickMarks TickMarksFrequency="100" UseFrequency="True" HorizontalTickMarksTemplate="{StaticResource HorizontalTick}"/>
</ig:XamNumericRangeSlider.TickMarks>
<ig:XamSliderNumericThumb Value="{Binding Path=VoltageRangeSlider.SafetyMin, Mode=TwoWay, NotifyOnSourceUpdated=True}" BorderBrush="Yellow" BorderThickness="10" Background="Brown" TrackFillBrush="Yellow" IsDragEnabled="False"/>
<ig:XamSliderNumericThumb Value="{Binding Path=VoltageRangeSlider.SafetyMax, Mode=TwoWay, NotifyOnSourceUpdated=True}" IsSnapToTickEnabled="True" />
<ig:XamSliderNumericThumb Value="{Binding Path=VoltageRangeSlider.Max, Mode=TwoWay, NotifyOnSourceUpdated=True}" BorderBrush="Red" BorderThickness="10" Background="Red" TrackFillBrush="Red" Visibility="Visible"/>
</ig:XamNumericRangeSlider>
  • 6759
    Hi Kinsly,
    I assume you want to display the Thumb's value somewhere on/around the thumb so I would suggest you to use the thumb style and re-template the thumb and bind it's value.
    You could check out the following sample that is illustrating the approach(don't mind the Silverlight sample - the Control is basically the same in WPF but SL makes it a bit easier to share).
    Hope this helps. Let me know if I could be of more help on this matter.
