185
XamNumericEditor allows pasting out of range values
I'm using version 15.1 for the XamNumericEditor editor.
I want to limit the end user to enter a value between 1 and 400 in the editor.
The only problem occurs when the user pastes a value out of range. The editor still accepts the value and displays the out of range value.
Here's what I have for the editor:
<igEditors:XamNumericEditor Width="50"
SpinButtonDisplayMode="Always"
IsAlwaysInEditMode="True"
AlwaysValidate="True"
SpinIncrement="1"
DataMode="Raw"
Mask="{}{char:3:0-9}%"
PromptChar=""
InvalidValueBehavior="RevertValue"
ValueType="{x:Type sys:Int64}"
Value="{Binding ImageWidthTransform, Mode=TwoWay, UpdateSourceTrigger=PropertyChanged}"
<igEditors:XamNumericEditor.ValueConstraint>
<igEditors:ValueConstraint Nullable="False" MinInclusive="1" MaxInclusive="400" />
</igEditors:XamNumericEditor.ValueConstraint>
</igEditors:XamNumericEditor>
I used the property InvalidValueBehavior and set it to "RevertValue" because I want to revert the value if an invalid/out of range value gets pasted into the editor.
The value never gets reverted.
I also tried to set the mask to "number:1-400" instead of the ValueConstraint, but still the same result.
Though the editor disables the up/down arrows if the value reached the max/min value. Also, typing the value will limit it to max value of 400. But pasting the value will not be limited.
Any ideas?
