1770
Saving of layout not functioning as expected
Hello. I've attached a project that is laid out the same as my main project to illustrate my issue. What I want is keep the same layout of panes as I switch from user control to user control. The problem is that that is not happening initially when I go from view 3 (default view when application starts) to view 4. When I switch between different views the layout of the previous view is saved and then that layout is loaded for the next view so it should work.
Just to be clear of the steps:
1.start the application. The North pane is pinned and South pane is unpinned.
2.Click on "View 4" on the left hand side. Now both South and North panes are pinned but the layout should be the same as in "View 3".
Please have a look at the project and this will make sense.
DockManagerTest.zip
