185
XamRichTextEditor check Document for equality and empty
I am using the XamRichTextEditor in an XamGrid TemplateColumn and i have problems by comparing the richtextdocument. What i want to achieve is that if a user clicks in the cell and updates something in the XamRichTextEditor document i want to save the new version in the database.
I have the following xaml column configuration:
                            HorizontalContentAlignment="Stretch" VerticalContentAlignment="Stretch" >
                                                              ClipboardOperationExecuting="DescriptionEditor_OnClipboardOperationExecuting"
                                              GotFocus="DescriptionEditor_OnGotFocus"LostFocus="DescriptionEditor_OnLostFocus" Height="Auto"/>
        RefreshTrigger="Delayed" DelayAfterLastEdit="00:00:01.00" Visibility="Collapsed"
                                                 Value="{Binding Document}"/>
I have handled the following two events for this:
1) OnGotFocus -> Here i am saving the current RTF document to a stream by using the SaveToRtf method
2) OnLostFocus -> Her i am saving the new/updated RTF document to a stream by using the SaveToRtf method
The problem is now that if the user doesn't change anything i also get differences betweent the two streams. Why is that? Whats the Problem here?
How can i check if two rtf documents are equal? And how can i check if an document is empty?
Also if i "Export Content" from the Samples Browser i get different output and cannot compare two rtf documents.
Thanks in Advance!
Best Regards
Rene
