I used the behavior from this article to bind to ItemsSource on XamDockManager: http://ko.infragistics.com/community/blogs/blagunas/archive/2013/09/24/xamdockmanager-data-binding-contentpanes-with-mvvm.aspx
I was having some weird issues with the DataContext still firing some CanExecute calls after the window was closed, so I added after the window closes to set the DataContext to null.
In the attached sample, right-click on any of the tabs and create a new vertical group (IMPORTANT). Then close the window and you'll get the exception below.
System.InvalidOperationException was unhandled HResult=-2146233079 Message=Cannot modify the logical children for this node at this time because a tree walk is in progress. Source=PresentationFramework StackTrace: at System.Windows.FrameworkElement.RemoveLogicalChild(Object child) at Infragistics.Windows.DockManager.SplitPane.Infragistics.Windows.DockManager.ISplitElementCollectionOwner.OnSplitterRemoved(PaneSplitter splitter) at Infragistics.Windows.DockManager.ObservableSplitElementCollection`1.OnCollectionChanged(NotifyCollectionChangedEventArgs e) at Infragistics.Collections.ObservableCollectionExtended`1.RemoveItem(Int32 index) at System.Collections.ObjectModel.Collection`1.RemoveAt(Int32 index) at Infragistics.Windows.DockManager.SplitPane.Infragistics.Windows.DockManager.IPaneContainer.RemovePane(Object pane) at Infragistics.Windows.DockManager.DockManagerUtilities.RemoveContainerIfNeeded(IPaneContainer paneContainer) at Infragistics.Windows.DockManager.DockManagerUtilities.RemoveContainerIfNeeded(IContentPaneContainer container) at Infragistics.Windows.DockManager.XamDockManager.DestroyPaneElement(IContentPaneContainer container, ContentPane pane) at Infragistics.Windows.DockManager.XamDockManager.ClosePaneHelperImpl(ContentPane pane, PaneCloseAction closeAction, Boolean raiseEvents, Boolean removeFromCurrentContainer) at Infragistics.Windows.DockManager.XamDockManager.ClosePaneHelper(ContentPane pane, PaneCloseAction closeAction, Boolean raiseEvents, Boolean removeFromCurrentContainer) at Infragistics.Windows.DockManager.XamDockManager.ClosePaneHelper(ContentPane pane, PaneCloseAction closeAction, Boolean raiseEvents) at Infragistics.Windows.DockManager.XamDockManager.ClosePanes(IList`1 panes) at Infragistics.Windows.DockManager.XamDockManager.ClosePane(ContentPane pane, Boolean includeSiblingsIfAllowed) at Infragistics.Windows.DockManager.ContentPane.ExecuteCommandImpl(ExecuteCommandInfo commandInfo) at Infragistics.Windows.DockManager.ContentPane.ExecuteCommand(RoutedCommand command) at WpfApplication4.TabGroupPaneItemsSourceBehavior.OnItemsSourcePropertyChanged(IList oldvalue, IList newvalue) in c:\users\jon\documents\visual studio 2015\Projects\WpfApplication4\WpfApplication4\MainWindow.xaml.cs:line 182 at WpfApplication4.TabGroupPaneItemsSourceBehavior.OnItemsSourcePropertyChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) in c:\users\jon\documents\visual studio 2015\Projects\WpfApplication4\WpfApplication4\MainWindow.xaml.cs:line 146 at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.Freezable.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue) at System.Windows.Data.BindingExpressionBase.Invalidate(Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.Activate(Object item) at System.Windows.Data.BindingExpression.OnDataContextChanged(DependencyObject contextElement) at System.Windows.Data.BindingExpression.HandlePropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.Data.BindingExpressionBase.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.Data.BindingExpression.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.DependentList.InvalidateDependents(DependencyObject source, DependencyPropertyChangedEventArgs sourceArgs) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.TreeWalkHelper.OnInheritablePropertyChanged(DependencyObject d, InheritablePropertyChangeInfo info, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1.StartWalk(DependencyObject startNode, Boolean skipStartNode) at System.Windows.TreeWalkHelper.InvalidateOnInheritablePropertyChange(FrameworkElement fe, FrameworkContentElement fce, InheritablePropertyChangeInfo info, Boolean skipStartNode) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value) at System.Windows.FrameworkElement.set_DataContext(Object value) at WpfApplication4.App.App_OnStartup(Object sender, StartupEventArgs e) in c:\users\jon\documents\visual studio 2015\Projects\WpfApplication4\WpfApplication4\App.xaml.cs:line 26 at System.Windows.Application.OnStartup(StartupEventArgs e) at System.Windows.Application.<.ctor>b__1_0(Object unused) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler) at System.Windows.Threading.DispatcherOperation.InvokeImpl() at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Threading.DispatcherOperation.Invoke() at System.Windows.Threading.Dispatcher.ProcessQueue() at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler) at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg) at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame) at System.Windows.Application.RunDispatcher(Object ignore) at System.Windows.Application.RunInternal(Window window) at System.Windows.Application.Run(Window window) at System.Windows.Application.Run() at WpfApplication4.App.Main() in c:\users\jon\documents\visual studio 2015\Projects\WpfApplication4\WpfApplication4\obj\Debug\App.g.cs:line 0 at System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args) at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args) at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly() at System.Threading.ThreadHelper.ThreadStart_Context(Object state) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ThreadHelper.ThreadStart() InnerException:
Then this exception:
System.InvalidOperationException was unhandled HResult=-2146233079 Message=Collection was modified; enumeration operation may not execute. Source=mscorlib StackTrace: at System.ThrowHelper.ThrowInvalidOperationException(ExceptionResource resource) at System.Collections.Generic.List`1.Enumerator.MoveNextRare() at System.Collections.Generic.List`1.Enumerator.MoveNext() at Infragistics.Collections.MultiSourceEnumerator.MoveNext() at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1.StartWalk(DependencyObject startNode, Boolean skipStartNode) at System.Windows.TreeWalkHelper.InvalidateOnInheritablePropertyChange(FrameworkElement fe, FrameworkContentElement fce, InheritablePropertyChangeInfo info, Boolean skipStartNode) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value) at System.Windows.FrameworkElement.set_DataContext(Object value) at WpfApplication4.App.App_OnStartup(Object sender, StartupEventArgs e) in c:\users\jon\documents\visual studio 2015\Projects\WpfApplication4\WpfApplication4\App.xaml.cs:line 26 at System.Windows.Application.OnStartup(StartupEventArgs e) at System.Windows.Application.<.ctor>b__1_0(Object unused) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler) at System.Windows.Threading.DispatcherOperation.InvokeImpl() at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Threading.DispatcherOperation.Invoke() at System.Windows.Threading.Dispatcher.ProcessQueue() at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler) at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg) at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame) at System.Windows.Application.RunDispatcher(Object ignore) at System.Windows.Application.RunInternal(Window window) at System.Windows.Application.Run(Window window) at System.Windows.Application.Run() at WpfApplication4.App.Main() in c:\users\jon\documents\visual studio 2015\Projects\WpfApplication4\WpfApplication4\obj\Debug\App.g.cs:line 0 at System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args) at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args) at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly() at System.Threading.ThreadHelper.ThreadStart_Context(Object state) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ThreadHelper.ThreadStart() InnerException:
if (newvalue == null || newvalue.Count == 0) { // clear all panes XamDockManager manager = XamDockManager.GetDockManager(base.AssociatedObject);
if (manager != null) { List contentpanes = manager.GetPanes(PaneNavigationOrder.VisibleOrder).ToList();
for (int i = contentpanes.Count - 1; i >= 0; i--) { ContentPane cp = contentpanes[i]; cp.CloseAction = PaneCloseAction.RemovePane; cp.ExecuteCommand(ContentPaneCommands.Close); } } }
The sample I sent has a foreach on the removing of the panes, but it still happens if I use a reverse for loop as well as shown above.
Please help! I need a workaround for this issue as soon as you can. Thanks!
Hi Jon,
Since the DataContext is getting set to null it triggers property change notifications which means the behavior's ItemsSource property is changed to null. This triggers the OnItemsSourcePropertyChanged event and then runs through that ExecuteCommand() code. But the window was closed so it's probably doing something with the visual or logical tree when that code fires thus the above exception.
I'm not sure what the proper solution would be, maybe you could wrap that close pane code in a try/catch and just handle the exception. Since the window is closing there's no reason to fire that code since it'll just get garbage collected anyway. It would be nice if .NET had a way to know when the tree is being walked when we try to use methods like AddLogicalChild or RemoveLogicalChild (the pane closing code uses RemoveLogicalChild which is what throws that exception) so we could just wait for it to finish but currently there's nothing exposed.
It turns out I don't need that snippet of close all panes code found in the behavior. So I am okay for now, but there is still some kind of issue going on here. Thanks!
