270
How to add an item programmatically
I try to add a item programmatically to the XamPropertyGrid. The Source is a ListItem witch will be generated dynamically. Each Item contains a Headernam, Value, Type of the value and a readonly flag. I want to display it like this:
Headername | Value
Headername |Value
How can I do this in the right way?
I added some lines with a little sample. The wanted output is
Name | Frank
Sourecode:
XAML:
<Window
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
        xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
        xmlns:local="clr-namespace:WpfApplication6"
        xmlns:ig="http://schemas.infragistics.com/xaml" x:Class="WpfApplication6.MainWindow"
        mc:Ignorable="d"
        Title="MainWindow" Height="350" Width="525">
    <Grid>
        <ig:XamPropertyGrid x:Name="propgrid"/>
    </Grid>
</Window>
Codebehind:
public partial class MainWindow : Window { public MainWindow() { InitializeComponent(); TransferObject frank = new TransferObject() { HeaderName = "Name", Value = "Frank", Typ = typeof(string), Readonly = false }; this.propgrid.SelectedObject = frank; } } public class TransferObject { public string HeaderName { get; set; } public object Value { get; set; } public Type Typ { get; set; } public bool Readonly { get; set; } }
