I need to bind a XamGrid to a CompositeCollection containing different ViewModels (which actually have similar named properties).Only the similar named columns are visible.Showing ViewModels of the same type is no problem, but in the moment I add another viewmodel type, the Xamgrid crashes with an error messagestarting like:
The object of type "AViewModel" cannot be casted to "BViewModel"
atSystem.Linq.Enumerable.<CastIterator>d__1`1.MoveNext()
atSystem.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext()
atSystem.Linq.Enumerable.Count[TSource](IEnumerable`1 source)
at Infragistics.DataManager`1.ResolveCount()...Is it even possible to use different ViewModels as ItemsSource?The rows need to be sortable as well.There seems to be no example code where such scenario is achieved.Somewhere in the forums, I read about the need of implementing IComparable on the viewmodels, but there seems to be no example code either.Thanks and best regards,Nils
Thank you for your post.
I have been looking into the functionality you are looking for and it seems that currently our XamGrid control is not design to show heterogeneous data. What I can suggest is to take a look at the following forum thread, where a similar question was discussed:
http://ko.infragistics.com/community/forums/t/92761.aspx
Please let me know if you require any further assistance regarding this matter.
