I have ComboBoxColumn which is binded to ObservableCollection, the ObservableCollection is being populated but I don't see any item in the combo drop down.
I attached the code, what do I miss?
Thanks.
Hello Dudi,
I hope you have resolved the issue.
If you require any further assistance, please do not hesitate to ask.
Sincerely,
Ok, understood.
There are some limitations related to the columns binding to dynamic collections.
You can see more information about this here: http://ko.infragistics.com/community/blogs/devin_rader/archive/2011/04/29/binding-to-properties-of-non-frameworkelements.aspx
You can bind the ComboBoxColumn ItemsSource to a StaticResource or you can use the workaround attached.
