175
buggy Series behavior
Hello Infragistics Engineers,
I've attached a sample that demonstrates some buggy behavior when trying to add a Series to a chart using procedural code.
Using the same function to add a series in the OnInitialized function produces different results than the same function used after the window is fully visible (which actually doesn't even work).
Maybe this is already fixed in a yet-to-be-released build?  Or there's a funny, specific way adding a Series should be done?
It would be nice to have in the docs a little more hand-holding/in-depth explanation on using the chart from procedural code.
XamChart is shaping up pretty nicely in most other areas.  Keep up the good work.
Zac Morris
Sample:
 XAML:
<igCA:XamChart x:Name="_chart" />
CS:
 using System;
using System.Collections.Generic;
using System.Windows;
using System.Windows.Input;
using System.Windows.Media;
using Infragistics.Windows.Chart;
namespace ChartSeriesBug
    public partial class Window1 : Window
        public Window1()
            InitializeComponent();
            _chart.MouseDoubleClick += _chart_MouseDoubleClick;
        private void _chart_MouseDoubleClick(object sender, MouseButtonEventArgs e)
            this.AddSeries(new Random().Next(), "After Initialized Procedural Series");
        protected override void OnInitialized(EventArgs e)
            base.OnInitialized(e);
            for (int i = 0; i < 2; i++)
                this.AddSeries(i, "OnInitialized Procedural Series");
        private void AddSeries(int i, string seriesLabel)
            Series series = new Series();
            series.ChartType = ChartType.Line;
            series.Label = seriesLabel;
            series.DataMapping = "Value=Watts; Label=Time";
            series.DataPointColor = DataPointColor.Auto;
            series.StrokeThickness = 2;
            series.Fill = Brushes.Red;
            series.Stroke = Brushes.Aqua;
            series.DataSource = new RandomReadings(i);
            _chart.Series.Add(series);
    public class RandomReadings : List<PowerReading>
        public RandomReadings(int offset)
            for (int i = 0; i < 10; i++)
                this.Add(new PowerReading
                    Time = new DateTime(2007, 12, 1, i, 0, 0),
                    Watts = i + offset
    public class PowerReading
        public DateTime Time { get; set; }
        public double Watts { get; set; }
