When xmGrid is bound to a collectionviewsource and source collection is ObservableCollection<DataItem>, grid's selection behaves in unexpectable way:
- sorted by a column 1 with unique value (guaranteed)
- active row is, for example, 5th from the top, regardless of absolute index (for example, 105th, ie top row is 101st)
- upon user's action, item in the observable collection got replaced (not added/removed) with another item but with the same column 1's value (for example, column 2 has value changed from 'pending' to 'actioned'
- row 105th jumps to the grid's top.
Same scenario, without active row being replaced, works as expected (row item is changed in-place, no jumps)
Is there any fix or workaround?
Cheers,
Alex
PS.I'm using 2015.2 .NET 4.0 version.
hi Petar,
I wish I could do that. It is against the company policy.
However, i found a workaround - i'm not replacing the item in the grid but copy all values except key's over. This effectively keeps same object reference in the collection so no jumping occurs.
Hello Alexander,
I have been looking into your issue and since it seems very particular I was wondering, if you have a project we can replicate it with, just so we are sure we are looking at exactly the same thing.
