I have a problem with the xamComboEditor when used with the classic theme in windows activated.
With Aero activated there is no problem, only if the classic theme is in use.
When the DropDown Menu closes it is not rerendered properly, so it looks like it is still open.
I managed to break it down to the use of the attribute AllowsTransparency on the window. If it is set to true the problem occurs.
The whole application with all its windows is designed to use it, so there is no way of disabling transparency.
In the attached picture you can see the problem.
If I focus the TextBox, only the select line shines through.
Code to reproduce with win classic theme activated:
<Window x:Class="ComboEditorTest.MainWindow" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:ig="http://schemas.infragistics.com/xaml" Title="MainWindow" Width="525" Height="350" AllowsTransparency="True" Background="{x:Null}" WindowStyle="None"> <Grid Margin="5"> <Rectangle x:Name="recBackground" Fill="Gray" RadiusX="5" RadiusY="5" Stroke="Black"> <Rectangle.Effect> <DropShadowEffect /> </Rectangle.Effect> </Rectangle> <Grid> <Grid.ColumnDefinitions> <ColumnDefinition Width="Auto" /> <ColumnDefinition Width="*" /> </Grid.ColumnDefinitions> <Grid.RowDefinitions> <RowDefinition Height="Auto" /> <RowDefinition Height="Auto" /> <RowDefinition Height="Auto" /> <RowDefinition Height="Auto" /> </Grid.RowDefinitions> <TextBlock Margin="5" VerticalAlignment="Center" Text="ComboBox" /> <ig:XamComboEditor x:Name="combo1" Grid.Column="1" Margin="5" IsEditable="False" /> <TextBlock Grid.Row="1" Margin="5" VerticalAlignment="Center" Text="ComboBox" /> <ig:XamComboEditor x:Name="combo2" Grid.Row="1" Grid.Column="1" Margin="5" IsEditable="False" /> <TextBlock Grid.Row="2" Margin="5" VerticalAlignment="Center" Text="TextBox" /> <TextBox Grid.Row="2" Grid.Column="1" Height="70" Margin="5" /> <Button Grid.Row="3" Margin="5" Content="Button" /> <TextBlock Grid.Row="3" Grid.Column="1" Text="Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua. At vero eos et accusam et justo duo dolores et ea rebum. Stet clita kasd gubergren, no sea takimata sanctus est Lorem ipsum dolor sit amet. Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua. At vero eos et accusam et justo duo dolores et ea rebum. Stet clita kasd gubergren, no sea takimata sanctus est Lorem ipsum dolor sit amet." TextWrapping="Wrap" /> </Grid> </Grid> </Window>
Hallo Tacho,
thanks for the Update, the new Service Release fixed this behaivor.
BR
Andreas
Hello,The development issue with ID of 214885 has been fixed and it is available in the latest Service Release. You can download the Service Release by logging in our web site and then going to Account\My Keys and Downloads page.Thank you for using Infragistics Components.
Hello Andreas,
I created the following case for you: 'CAS-170322-D7G9S1' and will update you through it. You could see it in your account in the 'Support Activity' page.
Thank you for choosing Infragistics.
I have been looking into the issue that you have described and I will need some more time to investigate it. I will follow up with my findings as soon as I am ready with my investigation.
Thank you for your patience and understanding.
Sample project attached
