65
How to set Field Name to a (Nested)Sub Property
 I'm using entity framework classes as my datasource
The class is OrderDetail which have these properties:
ID (int)
Item(Class Item)
Quantity (int)
Subtotal (decimal)
Class Item has these properties
ID (int)
Name (string)
So i set the xamDataGrid.Datasource =  List(of OrderDetail)
I want to show the columns: Item.Name, Quantity, and Subtotal
So I specified 3 fields. I'm having problem setting the Field Name for Item.Name. "Item.Name" doesn't work, if I use that I get a blank grid.
Is this at all possible? I can easily bind "Item.Name" within a ListBox DataTemplate, how do I this with xamDataGrid.
Thank you
