280
Changes with RecordsInViewChanged between v13.1 and 14.2
 I am using a xamDataGrid where in each row I display text on multiple lines which needs follow these conditions.
  • If the text can be displayed on 5 lines or less -> we display the full text, adjusting the height based on the number of lines displayed
  • If the text is longer than 5 lines -> we only display the 2 first lines and we add a button to display the full text in a separate dialog.
The way is currently working is that we adjust the MaxHeight for each record whether the control's size or the records in view changed.
Everything worked fine until we upgraded from Infragistics V13.1 to InfragisticsV14.2.
After the upgrade, we started to see a big blank space in our control where we should see records the first time the control is displayed. If we start scrolling down, the missing records magically appear and everything looks fine afterwards.
Do you know if any changes were made around RecordsInViewChanged that would impact what we are doing? Is there a way to force a refresh for the records that should be in view after adjusting the record's heights?
