195
Binding table-like data to XamSpreadsheet
Is there a way to bind a collection to the rows / columns in a worksheet of a XamSpreadsheet control?
(Like you would on a XamDataGrid via the DataSource property)
for example, to bind to an object like the one below, and display the data along columns:
public class SimpleTupleDataCollection : ObservableCollection<Tuple<double,double>>
public SimpleTupleDataCollection()
this.Add(new Tuple<double, double>(-0.8,1));
this.Add(new Tuple<double, double>(-1.8, 3.2));
this.Add(new Tuple<double, double>(-4.8, 3.0));
   - Nicolas
  • 34810
    Hello Nicolas,
    Thank you for your post.
    Currently, the XamSpreadsheet requires a Workbook as its "ItemsSource," and the worksheets of workbook objects do not have an available property that can be bound to collections or other table-like data structures. However, something that you could do is create a Worksheet object, loop through your data collection, and place this Worksheet in a Workbook element, which you can then give to the XamSpreadsheet. A tutorial on how to create a Worksheet and populate its cells can be found here: http://help.infragistics.com/doc/WPF/2015.2/CLR4.0/?page=IGExcelEngine_Creating_a_Workbook.html.
    If you would like to see data binding support for Worksheets added in the future, consider suggesting a new product idea at http://ideas.infragistics.com. As an Infragistics user, you can create or vote on product ideas that you find most interesting. This product ideas site allows you to be in direct communication with our product management team, track the progress of your idea at any time, read comments from other developers in the community, and see if someone from the product team has additional questions for you regarding your idea.
    Sincerely,
    Andrew
    Associate Developer
    Infragistics Inc.
    www.infragistics.com/support
