It's an example, just to describe my case :
I work at an automobile repair shop.
I have a list of cars and an unique list of issues to solve.
Each car and issue are unique, so a car can have a different issue than another one.
So I have a List<Car> Cars and Car.Issues.
For the control, if an issue is solved, the xamTile is collapsed. If an employee switch from one car to another one, issues states need to stay the same.
I try many things like PersitenceManager, PersistenceGroup and PersistenceInfo.
When I switch between cars, I save the state in the code behind, "alert" my viewModel and save it in my applicationContext.
I want to create a default context too, if a car hasn't been checked, a default view is here. At the opposite, if a car have already some fixs, I want to restore the state.
How I save this state ?
Thanks for your help
Regards
Hi teamtim,
This is a new issue so it would have been better to open a new thread instead. Since you have created a support case (CAS-174342-N6M4M0) to bring this issue to our attention we should continue this issue inside that support case from now on.
It was a month ago, and now this feature is blocking the release of a software.
I don't manage to restore the context of tiles, it's really important for my company to be a ble to save and restore the state of all tiles.
I'm back with an issue :
My software have one view with a DataGrid and a XamTileManager.
They both depends from a viewModel and a context to save DataGrid and XamTileManager details.
To be able to have a context by DataGrid item, I created an attachedProperty to my XamTileManager. It's allow me to save and restore settings with the PersitenceFramework.
I attached some files :
-My customProperty
-An extract of my architecture
Backup is fully functional, but when I load the configuration (line 123), it's impossible to maximize more than one item.
if there is a second item, he is hide at the background of the first. if I minimize the first maximized, all tiles are well displayed.
I try to set the maximizedTieLimit and sizes, without improvements. The line to be changed is maybe at the line 155.
Could you help me to have both tiles mazimized ?
Hello teamtim,
The ItemTileInfo lists contain information about each of the tiles, and since you are saving a list of these for each of your items, it will include a list of a item information about the tiles that exist for each item. I am assuming that you are currently wondering how to get the ItemTileInfo information into the tiles that represent your item, so please correct me if I am wrong. After you load your layout and the XamTileManager's layout loads, you can look at your data and get each tile that exists for the newly selected data items by using the XamTileManager.TileFromItem method. Using this method, you can pass your data items that you have selected for display in the XamTileManager, receive the XamTile that represents those data items, and then you can look at your list of ItemTileInfo elements to apply those settings to the tiles that exist for those elements.
Regarding the animation-related event in the XamTileManager, I would expect that your selection in your XamDataGrid would happen prior to this animation event being fired for the XamTileManager. If this is the case, I would recommend that addition of a globally accessible bool flag that you can check in your AnimationEnded event handler, which can be set in the XamDataGrid.SelectedItemsChanged event, as that will fire when you select a new row in your XamDataGrid. As an alternative, I imagine you could also set this flag prior to the code that you are using to change the display of the XamTileManager, as I imagine that you are likely programmatically changing it.
If this flag is set to a certain value, you could check that value in the AnimationEnded event, and prevent the save if necessary.
Sincerely,AndrewAssociate DeveloperInfragistics Inc.www.infragistics.com/support
I want to save a context for each CarsSelection. The current context about issues values is stored in the IDisplayContext.
I manage to save all itemTileInfo with List for each CarsSelection.Item, but for the restore step, I don't know how to do.
My software is saving informations at animation.Ending, but I don't how to prevent the saving if the user change his current view so a restore is "needed".
Could you help me ?
