I am Binding a column twice in a XamDataGrid and getting exception as Field name was not found in data source. Is this feature is not there in XamDatagrid . Please reply soon if you have a solution for this as I need to bind dynamically a column twice in a XamdataGrid.
Sridhar
I have same problem with Sridhar. Have you solved this already? Can you share it? Thank you very much in advance.
Regards!
Hello Sridhar,
Using Infragistics Developer Support is a better medium for getting answers fast. I'm not sure how you are trying to apply a double binding. If you contact our support team, they can work with you until you figure out this problem.
http://ko.infragistics.com/gethelp/default.aspx#Overview
Thanks and good luck!
