85
Set the split panes width and height correctly.
I am using the following xaml for laying out my application's UI using XamDockManager.
 <Grid x:Name="mainGrid" >
            <DockPanel>
                <!--The docking manager and the controls contained within-->
                <dock:XamDockManager x:Name="dockingManager" Theme="Office2k7Black" Margin="0" DockPanel.Dock="Bottom">
                    <dock:XamDockManager.Panes>
                 //first split pane
                  <dock:SplitPane dock:XamDockManager.InitialLocation="DockedTop">
                            <dock:ContentPane>
                                //some control contained within
                            </dock:ContentPane>
                            <dock:ContentPane>
                            </dock:ContentPane>
                   </dock:SplitPane>
                   //second split pane -
                    <dock:SplitPane dock:XamDockManager.InitialLocation="DockedBottom">
                            <dock:TabGroupPane dock:SplitPane.RelativeSize="100,200">
                                <dock:ContentPane>
                                </dock:ContentPane>
                                <dock:ContentPane>
                                </dock:ContentPane>
                            </dock:TabGroupPane>
                        </dock:SplitPane>
                    </dock:XamDockManager.Panes>
                </dock:XamDockManager>
            </DockPanel>
        </Grid>
Using the above code and the xamDockManager the two splitpanes contained within the XamDockManager.Panes collection do not fill the screen appropriately. The split panes are having their own width and height. There is also certain gap between the two split panes.
How can I adjust the split panes' width and height to be based on the screen's dimensions and also there should not be any gap between the two split panes.Also how can the first split pane occupy most of the UI while the second one docks to the bottom.
