455
delete item based on selection
hey everyone,
got a little problem. Let's say I have 2 docuents in my xamdatagrid and I only want to remove 1 of them. So I'll highlight it and click my delete button. the only problem is I dont konw which option will only select the highlighted record. i either delete both or niether. here's the code that I have so far.
   Private Sub  Private Sub btnDelete_Click(ByVal sender As System.Object, ByVal e As System.Windows.RoutedEventArgs) Handles btnDelete.Click
        If xamDocGrid.ActiveRecord Is Nothing Then
            MessageBox.Show("You must select a document to Delete", "No Active Document Warning", MessageBoxButton.OK, MessageBoxImage.Information)
        Else
            ' For Each row As DataRow In dtDocs.Rows
            ' If Not xamDocGrid.ActiveRecord Is Nothing Then
            xamDocGrid.Records.ElementAt()
            ' row.Item("Active") = False
            'End If
            'Next
            Try
                    If row.Item("Active") = False Then
                        row.Delete()
                    End If
                Next
            Catch ex As Exception
                Return
            End Try
thanks in advance
Joel
