2085
XamGeographicMap Performance
We are using XamGeographicMap to display a heat map of data points for geo locations (for example, NOAA temperature data) that is resolved into a grid of about 5 mile intervals.  This translates into adding 90,000 geolocations with a temperature value into the XamGeographicMap for each group/time we want to display in an animation (typically we will show a 24 hour animation).  We are running into some performance and display issues, namely:
The triangulation operation on this data takes a long time (20 seconds or more) per group of data (typically 90,000 data points) - are there any recommendations on how to speed this process up?  We need to cache 24 times this amount for a 24 hour animation.
The resulting display can use 40 MB or more of memory per group of 90,000 points which can reach 1 GB if 24 hours of data for hourly animation is pre-loaded - is there a away to compact this memory footprint?
Is there a way to have two ranges of Color scales instead of one - for example show various shades of blue for temperatures below 32 degrees and various shades of red above 100 degrees, but ignore drawing (or make the color transparent) for temperature values between 32 and 100?  Currently the CustomPaletteColorScale has min/max values to generate colors for as an inclusive range, not an exclusive range.  We attempt to create a color scale that includes a transparent color in the middle of the scale, but that is less desirable than just excluding that range from being considered.  Also, how is the color scale matched up to a color value?
Attached is example code that generates a random value set (Lat, Lon, Value) of about 140,000 geo location data points in a periodic 5 mile grid format and renders them - this mimics how we get data and put it into the control.
WeatherMapPerfExample.zip
