920
Exporting to excel - Cell formats
I need to export the same format as what I display. I am wiring up the CellExportingEvent. I am not sure how I should translate the formats in this event.
<igDp:Field HorizontalContentAlignment="Right" Format="G4" .../>
<igDp:Field HorizontalContentAlignment="Right" Format="F2" .../>
To keep the formats in the UI and this event consistent, I tried binding the Format property to a string on the UI and use the same string in the event. But it is not working. How can I do this?
public string FormatF2
get{return "F2";}
<igDp:Field HorizontalContentAlignment="Right" Format="{Binding FormatF2"} Name="score".../>
protected override void FormatCell(object sender, CellExportingEventArgs e)
switch (e.Field.Name)
case "score":
e.FormatSettings.FormatString = FormatF2; // This does not work
// e.FormatSettings.FormatString = e.Field.Format // This does not work either
break;
