I have two panes in the dockmanager and I want to set the upper pane to 75%(3*) and lower pane to 25%(*) height. How to achieve this?
AllowMinimizeFloatingWindows="True" LayoutMode="FillContainer" Theme="Metro">
Hello Ramesh,
Thank you for your post.
Currently, the Height and Width properties of the SplitPane in the XamDockManager are set to be a double type, and so they do not accept * based width and height values. The reason that some controls do accept those values is because they are of the type GridLength, which allows * values.
As a workaround to this, I would recommend binding your SplitPane's Height property to the XamDockManager's ActualHeight property, and using a converter to calculate your * values, where usage of 3* and 1* would be ActualHeight * .75 and ActualHeight * .25, respectively. I have attached a sample project that demonstrates how this could be achieved.
If you would like to see SplitPane height and widths changed to support * values in the future, I would recommend suggesting a new product idea for this feature at http://ideas.infragistics.com. This product ideas site places you in direct communication with our product management teams who plan and prioritize upcoming products and features.
Sincerely,AndrewAssociate DeveloperInfragistics Inc.www.infragistics.com/support
<dockManager:XamDockManager AllowMaximizeFloatingWindows="True" AllowMinimizeFloatingWindows="True" LayoutMode="FillContainer" Theme="Metro"> <dockManager:XamDockManager.Panes> <dockManager:SplitPane MinHeight="200" dockManager:XamDockManager.InitialLocation="DockedBottom"> <dockManager:ContentPane CloseButtonVisibility="Collapsed" Header="Output"> </dockManager:ContentPane> </dockManager:SplitPane> <dockManager:SplitPane MinHeight="200" dockManager:XamDockManager.InitialLocation="DockedTop"> <dockManager:ContentPane CloseButtonVisibility="Collapsed"> <ContentPresenter Content="{Binding ContentView}" /> </dockManager:ContentPane> </dockManager:SplitPane> </dockManager:XamDockManager.Panes> </dockManager:XamDockManager>
