Hello.I have the next problem.For example i have 2 pane: in the first I use WindowsFormsHost, in the second I have button which show popup with checkboxes. When pane is pinned everything works fine. When I unpinned my second pane, click event of popup's checkboxes doesn't raise and checkbox state doesn't change. See the picture.
Thanks.
Tayyaba,
Development issue 220068 was logged for this behavior and a fix was made and released in a service release in July of 2016. This fix should be in the latest service release of 2015 Volume 2 and 2016 Volume 1 as well as the release of 2016 Volume 2. If you are using an older version, please upgrade and test if the behavior is resolved. If you are already using a newer version, please provide us with a sample so we can look into what might be happening.
Hi Michael,
Is this issue been resolved now? Or is it still in progress.
I'm facing the exactly same issue that Andrey posted, and i'm looking for its solution.
Please let me know what needs to be done to make things work right.
Tayyyaba
Hello Andrey,
Thank you for providing a sample that demonstrates the issue as well as how to work around this. The WindowsFormHost removed will prevent this issue from occurring, however
to ensure this is fixed, I have created case for you with an ID of CAS-173767-P8Z3Y8. You could reach your case following the link bellow:
https://ko.infragistics.com/my-account/support-activity I will update you via the mentioned case, so if you have any further questions or comments please update your case.
Hello Michael.
I attached project with problem. Also I attached gif file in the zip archive with reproducing. Lets me know if you have any questions.
I need checkboxes in the popup to be working properly (pane should be unpinned) and the other pane have WindowsFormsHost.
Please attach a sample demonstrating the issue and clarify/list your requirements please?
Thank you.
