625
WPF XamComboEditor do not add the new item
I am using the XamComboEditor (Infragistics.Controls.Editors) in order to create an AutoCompleteBox.
The following show my autocompletebox:
    public class AutoCompleteBox : XamComboEditor
        public int MruListMax
            get { return (int)GetValue(MruListMaxProperty); }
            set { SetValue(MruListMaxProperty, value); }
        // Using a DependencyProperty as the backing store for MruListMax.  This enables animation, styling, binding, etc...
        public static readonly DependencyProperty MruListMaxProperty =
            DependencyProperty.Register("MruListMax", typeof(int), typeof(AutoCompleteBox), new PropertyMetadata(50));
        public AutoCompleteBox()
            this.CustomValueEnteredAction = CustomValueEnteredActions.Add;
            DropDownButtonDisplayMode = DropDownButtonDisplayMode.Never;
        protected override void OnItemAdded(ComboEditorItem item)
            base.OnItemAdded(item);
            ObservableCollection<string> itemSourceLIst = this.ItemsSource as ObservableCollection<string>;
            if (itemSourceLIst.Count > MruListMax)
                itemSourceLIst.RemoveAt(0);
And the AutocompleteBox has been added to the view as shown here:
    <Grid>
        <Grid.ColumnDefinitions>
            <ColumnDefinition Width="*" />
        </Grid.ColumnDefinitions>
        <Controls:AutoCompleteBox ItemsSource="{Binding MruList}" VerticalAlignment="Top" />
        <ListBox ItemsSource="{Binding MruList}"
                 Grid.Column="1" />
    </Grid>
My problem is that i do not add the correct new item. If my MruList contains the following : Dennis, Denny, and I enter "Denni" in the comboBoxEditor, the when I click Enter or uses Tab, it do not add "Denni" to the MruList, instead it chooses "Dennis" which are already in the list?
How can I prevent it from suggesting "Dennis", when i only type in "Denni"?
Best Regards!
Dennis
Using 15.1
Parents Reply Children
No Data
