525
Blip in spline series chart
Hi. I am using a Spline Series to display a curve. I dont want to show some points at the beginning, so I fill the array with NaN. But when I display this I see a little blip at the beginning. Has anyone seen a similar issue and how can it be fixed?
I am including a picture to show the problem (file attached).
Thanks.
  • 34510
    Hi sudnya_s,
    Do you have a sample you can attach that reproduces this blip?  I'm not really sure how to go about trying to reproduce this.  I have a sample where the first couple points are set to double.NaN and afterwards they are set to actual values but I don't see any blips.  Maybe it is that specific set of data that causes the issue?  Have you tried rendering a different data set and seeing if the blip still occurs.  If you change the data and the blip disappears, try sending me the actual data points in a text file so I can try loading them into my own sample.
    SplineRender.zip
