Is there a setting to turn the copy and paste on the xamDataGrid. I found an old post on this forum, however I could not open the solution.
Can you please provide an example how to implement CTRL+C (a row) / CTRL+ V (on the xamDataGrid it self).
Thank you
Hello, In order to set the clipboard operations that are allowed within the XamDataGrid, you can use the AllowClipboardOperations property of the FieldLayoutSettings. <igDP:XamDataGrid.FieldLayoutSettings> <igDP:FieldLayoutSettings AllowClipboardOperations="All" /></igDP:XamDataGrid.FieldLayoutSettings> In order to copy and paste records by using the Ctrl+C and Ctrl+V commands, you can use the built-in copy and paste functionality of the XamDataGrid by using the RecordSelector. If no space is available for pasting multiple records I can suggest you use the AddNew record, which will automatically paste the new records in the XamDataGrid.I have prepared an application, where this behavior is implemented.If you require any further assistance on this matter, please do not hesitate to ask.
