65
Alignment of Marker in ColumnSeries
How can I change the position of Marker on Column series?
I've created DataTemplate for MarkerTemplate in YAXis
<DataTemplate x:Key="MarkerTemplate">
    <TextBlock Margin="5,0,0,5" Text="{Binding Item.YAxisData}" Foreground="Black" FontSize="10" >
        <TextBlock.RenderTransform>
            <RotateTransform Angle="-90"/>
        </TextBlock.RenderTransform>
    </TextBlock>
</DataTemplate>
The problem is, when I set a marker as a vertical text, it's not aligned with the column and the tick under it.
When it's horizontal it's fine. Also, it would be great if the solution you provide works well with the zoom as well.
