65
Bind field to custom object
I'm using an ObjectDataProvider for an xamDataGrid. My datasource is a Generic List of a custom object. One of the properties of this object is a custom object with some more properties that I would like also to show on the datagrid but I don't know how. If I set AutoGenerateColumns to true it just gives me a column of that custom object and shows the name of the object in every cell of the column rows...
Juan Puebla
  • 138253
    Hello Juan,
    It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. So I have been looking through you post and I can suggest you use UnboundField to show this custom object properties. You can set its BindingPath property directly to the XamDataGrid’s underlying data object’s properties. If you have a Date property of DateTime type in you underlying object e.g you can set the UnboundField’s BindingPath property to Date.Year in order to display only the Year.
