Is it possible to have different filters for each field?
E.g In a string field I only want to use the "Contains" filter and for an numeric field, I want to use "GreaterThan, LessThen and Equal".
Hello Markus,
In order to have only certain items in the Filter Operators’ list I suggest using the FilterOperatorDropDownItems property off the FieldSettings object and set it to the comma separated list of operator values you need. The code should look similar to the following snippet:
<igDP:FieldSettings
FilterOperatorDefaultValue="Equals"
FilterOperatorDropDownItems="GreaterThan, LessThan, Equals"/>
I implemented the suggested approach in the sample application I am attaching for you reference. Please let me know if I can provide any further assistance.
