Hello!
I used WidthConverter, introduced by your developer Valerie (http://ko.infragistics.com/community/forums/p/83624/508991.aspx#508991) for text wrapping (example attached) and had a problem:if I add a new element to the collection, when text of some node is not on the next line, then new node is automatically marked as active and is scrolled to a visible zone. This situation is considered to be normal.
But when a text is already on the next line, then new added node is placed lower and remains invisible.
Please help
Alex
Hello Alex,
This issue has been assigned to the developer and is currently being investigated. At this time, I do not have a timeframe for the resolution. I will update you again when I have more information.
As far as the XamGrid is concerned I took a quick look at scrolling with various height columns and I did not notice any issue. If you can provide me with more details (or a sample) on the issues you are seeing with the XamGrid, I can investigate that further.
Sincerely,
Valerie
Software Developer
Infragistics Inc
Hello, Valerie!Thanks for your attention to this issue.Currently, we are testing our application and found analogous problem with XamGrid.
Could you please tell when this issue can be fixed?
It appears there is an issue with the scrolling when the height of all the nodes are not the same. I have asked our engineering staff to examine this further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 227644.The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution.
I have created a case, CAS-178226-V2T6X9, to track this issue and notify you of any changes in the status.
