Here my steps:
1. Existing application with registered version 2016.1 using nuGet-packegaes workes fine.
2. Installed Infragistics_Professional_20162_WithSamplesAndHelp using my new license key.
3. Didn't find the new nuGet packages.
4. Called repair of Infragistics_Professional_20162_WithSamplesAndHelp with checkmark for nuGet packages set.
5. Integrated nuGet packages into my own nuGet repository.
6. Modified my application to use the new nuGet packages.
7. Application shows a small window in the lower right that it is using an unlicensed trial.
8. Called "Update your installed products with a nnew priduct key" with my license key (it was already mentioned in the textbox).
9. Rebooted the PC.
10. Rebuild all of the application.
Still there is this small window in the lower right telling me that I'm using an unlicensed trial.
Can you tell me, what I can do in order to get rid of this window?
Michael
Sorry, yes it has. For some reason I managed to get the original 1006 installed into my application, when the parent case was still showing as on progress I just, wrongly, made the assumption it was not fixed.
Hi tankbob,
This issue appears to have been resolved in version 16.2.20162.2045. Installing the service release for that version should install the licensed version of the NuGet packages. If you are seeing a different behavior, please let me know.
Sincerely,AndrewAssociate Developer
Hi Andrew,
I posted onto the support case also, do you have updated packages for the new service release?
Hello Benedikt,
I have created case CAS-179725-R9G0T2 so that I can provide you with the fixed NuGet packages. You can access this case at https://ko.infragistics.com/my-account/support-activity.
Is it possible to get a copy of the fixed nuget packages too?
Thanks.
