405
Xamgrid bound to viewmodel with properties known at runtime
Good morning.
I was wondering if you could provide a small sample that shows how to create a xamgrid bound to a viewmodel with a number of properties known only at runtime. Each of these properties would have their own column and would be editable.
I found a good example for the xamdatagrid but I need this to work for the xamgrid.
Here is the link to the xamdatagrid sample. It explains really well what I need.
http://ko.infragistics.com/community/blogs/blagunas/archive/2012/10/24/xamdatagrid-dynamically-create-and-data-bind-columns-with-an-editor-of-your-choice.aspx
Thank you in advance
  • 29105
    Hello Roberta,
    Thank you for contacting Infragistics. I've attached a sample below that binds the XamGrid to the StaffMembers ViewModel, aquired from the link you've posted. The only differences from using the XamDataGrid is that you need to reference the ItemSource property to hook up the binding and create a EditingSettings reference to set the AllowEditing property to Row, cell etc.
    eg.
    <ig:XamGrid x:Name="MyGrid" ItemsSource="{Binding StaffMembers}">
                <ig:XamGrid.EditingSettings>
                    <ig:EditingSettings AllowEditing="Row"></ig:EditingSettings>
                </ig:XamGrid.EditingSettings>
    </ig:XamGrid>
    Let me know if you have any questions regarding this matter.
    ViewModelBinding.zip
