100
IndexOutOfRangeException in ValidateIndex method of InfragisticsWPF4.v16.1.dll
Hello!
We have recently tried in our company to switch XamDataGrid in one of our products to grouping, sorting and filtering using CollectionView like that:
<igDP:XamDataGrid.FieldLayoutSettings>
<igDP:FieldLayoutSettings
SortEvaluationMode="UseCollectionView"
GroupByEvaluationMode="UseCollectionView"
FilterEvaluationMode="UseCollectionView"
SummaryEvaluationMode="UseLinq"
</igDP:XamDataGrid.FieldLayoutSettings>
Every 3 seconds 5000 records is added to the collection that is a datasource for the grid. The records are added in the UI thread. Some records contain child records. If, during the time of that recurring record addition, I try to do something in the grid, for example, expand some group or scroll through the displayed records, I get IndexOutOfRange exception in the ValidateIndex method of InfragisticsWPF4.v16.1.dll.
Here is the full stack trace:
InfragisticsWPF4.v16.1.dll!Infragistics.Collections.SparseArray.ValidateIndex(int index = 19893) Line 2297 C#
InfragisticsWPF4.v16.1.dll!Infragistics.Collections.SparseArray.SetItemHelper(int index = 19893, object item = {Infragistics.Windows.DataPresenter.DataRecord}, bool performingAdd = false) Line 2195 C#
InfragisticsWPF4.v16.1.dll!Infragistics.Collections.SparseArray.this[int].set(int index = 19893, object value = {Infragistics.Windows.DataPresenter.DataRecord}) Line 2317 C#
InfragisticsWPF4.DataPresenter.v16.1.dll!Infragistics.Windows.DataPresenter.DataRecordsSynchronizer.Process_CollectionChangedWhenAsyncResetPending(object sender = Count = 19894, System.Collections.Specialized.NotifyCollectionChangedEventArgs e = {System.Collections.Specialized.NotifyCollectionChangedEventArgs}) Line 121 C#
InfragisticsWPF4.DataPresenter.v16.1.dll!Infragistics.Windows.DataPresenter.ListSynchronizer<object,Infragistics.Windows.DataPresenter.DataRecord>.OnSource_CollectionChanged(object sender = Count = 19894, System.Collections.Specialized.NotifyCollectionChangedEventArgs e = {System.Collections.Specialized.NotifyCollectionChangedEventArgs}) Line 232 C#
> System.dll!System.Collections.ObjectModel.ReadOnlyObservableCollection<System.__Canon>.OnCollectionChanged(System.Collections.Specialized.NotifyCollectionChangedEventArgs args) Unknown
System.dll!System.Collections.ObjectModel.ReadOnlyObservableCollection<System.__Canon>.HandleCollectionChanged(object sender, System.Collections.Specialized.NotifyCollectionChangedEventArgs e) Unknown
System.dll!System.Collections.ObjectModel.ObservableCollection<object>.OnCollectionChanged(System.Collections.Specialized.NotifyCollectionChangedEventArgs e) Unknown
System.dll!System.Collections.ObjectModel.ObservableCollection<System.__Canon>.InsertItem(int index, System.__Canon item) Unknown
mscorlib.dll!System.Collections.ObjectModel.Collection<object>.Add(object item) Unknown
PresentationFramework.dll!MS.Internal.Data.CollectionViewGroupInternal.Add(object item) Unknown
PresentationFramework.dll!MS.Internal.Data.CollectionViewGroupRoot.AddToSubgroups(object item, MS.Internal.Data.LiveShapingItem lsi, MS.Internal.Data.CollectionViewGroupInternal group, int level, bool loading) Unknown
PresentationFramework.dll!MS.Internal.Data.CollectionViewGroupRoot.AddToSubgroup(object item, MS.Internal.Data.LiveShapingItem lsi, MS.Internal.Data.CollectionViewGroupInternal group, int level, object name, bool loading) Unknown
PresentationFramework.dll!System.Windows.Data.ListCollectionView.PrepareGroups() Unknown
PresentationFramework.dll!System.Windows.Data.ListCollectionView.PrepareLocalArray() Unknown
PresentationFramework.dll!System.Windows.Data.ListCollectionView.RefreshOverride() Unknown
PresentationFramework.dll!System.Windows.Data.CollectionView.RefreshInternal() Unknown
PresentationFramework.dll!System.Windows.Data.CollectionView.Refresh() Unknown
Moreover, grid's filters work very unstable. Sometimes, they stop working after several filtrations.
Any solution to that problem will be highly appreciated!
