Hello,We have shipped out a new service release where your issue is resolved. I'd be glad to find out if you had tested it out and if it had met your requirements.You can download the Service Releases by logging to our web site and going to Account\My Keys and Downloads page.Thank you for using Infragistics Components.
Mi Maria
I have uploaded the sample application to the Support Activity Section
Best Regards
You can attach the sample application to the private case I have created on your behalf. The case number is CAS-179935-B3H2Z5 and can be accessed when you log in at our site and navigate to the Support Activity section.
We have extracted and cut down a piece of our application for use as test bed for reproducing the error conditions.
Do you have an email address that we can email the zipped solution to as it has sensitive IP in it that we do not want to post on an open forum ?
Hello,I have put a sample application together testing with the IG Theme set and without setting a theme and the exception was not thrown on my side. This was tested with 16.1.20161.2033 and 16.2.20162.1006 builds you have mentioned.Please run the attached sample project and modify it to illustrate the scenario on your side so I can investigate this further for you.
