I'm using Infragistics 16.1 xamMultiColumnComboEditor. I want to convert the column text from bool to string. For example, say I have Person Class and RelationShip property as bool I want to display it as Single/Married in the RelationShip column of the xamMultiColumnComboEditor. Can you please advise on it?
Hello Manojkumar,
Thank you for contacting Infragistics. I modified and reattached your sample to utilize a converter for your TextComboColumn. The column objects expose a ValueConverter property which you can bind to a static resource that utilizes a class you'll need that implements IValueConverter. This class can change True and False values to any output you want as a string.
Please see the sample attached for more details and let me know if you have any questions.
