I first looked into hierarchical/nested data which worked well for me except that it was too much code trying to get the parent and child columns to synchronize (when columns are moved, resized, filtered, sorted etc). I am now looking into Group By. I only want groups to show when there are more than one item so for example, in the attached screenshot, I would like the groups 1000 and 1001 to show as the individual records instead of as groups of one item.
Can you please advise how I can achieve this?
Furthermore, is it possible to hide the group functionality from the user but to do it behind the scenes?
Thank you.
Was there ever a resolution to this?
This functionality is what I am looking for at the moment.
I was researching your inquiry and find out it needs more time to investigate.I have created a private support case with an ID of CAS-180533-C3D6F1 for you and I will continue assisting you via this support case. In order to view it on pur web site please follow these steps:
1) Log in with your account on our web site - https://ko.infragistics.com
2) From the Support/Account menu item select View Account Info. This will lead you to My Keys & Downloads page - https://ko.infragistics.com/my-account/keys-and-downloads
3) From the menu on the left side of the page select Support Activity - https://ko.infragistics.com/my-account/support-activity
There you will find a list with all the active cases.
Please let me know if you have any additional questions regarding this matter.
Best Regards.
