1925
xamDiagram nodes alignment for newly created objects
Referring to http://ko.infragistics.com/samples/wpf/diagram/binding-nodes-with-objects
Can you please suggest recommended way of aligning new nodes if a child node is created on fly. I have set TreeDiagramLayout's NodeFlowDirection to "Below" but when a new object is added in viewmodel at run time it goes to top left corner of diagram.
Ideally starting from parent, I would like nodes to be center aligned and newly created to be below parent node.
