40
Multiple Datasources as Cubes in xamPivotGrid
I need to analyse different data in the same view.
Can I bind multiple FlatDatasources or multiple Excel Sheets in one xamPivotDataSelector?
Each datasource/sheet should be one cube with different measure Groups.
Thanks.
  • 17475
    XamPivotDataSelector supports a single FlatDataSource as a data source. You need to reset the DataSource property in order to load another source object.
    You can suggest the multiple FlatDataSource support as a new product idea for future versions at http://ideas.infragistics.com.
    Submitting your idea will allow you to communicate directly with our product management team, track the progress of your idea at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
    Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. You can also link back to this thread for additional details.
    Thank you in advance to submitting your product idea.
