190
Disabling Undo/Redo in XamNumericEditor
I have a Problem implementing my Undo/Redo.
I'm using the UndoManager in the Viewmodel to implement Undo/Redo functionality. To achive that I use the AddPropertyChanged Method in the Properties of my Viewmodel.
In the View I have a Toolbar with Buttons for Undo/Redo hooked up with the corresponding ApplicationCommands.
Now my Problem:
If the XamNumericEditor is in EditMode it catches the the ApplicationCommands before I get them in the ViewModel. Thus I can't handle them myself.
I need to stop the XamNumericInput from intercepting the ApplicationCommands for Undo and Redo, just like I would do with the IsUndoEnabled Property of a Textbox.
On my search for a solution I found only few posts, but none of them works for me.
http://ko.infragistics.com/community/forums/t/66798.aspx
http://ko.infragistics.com/community/forums/p/37758/219144.aspx#219144
Also I can't use the PreviewCanExecute and PreviewExecuted Events as I'm stacking Views on top of each other and need the topmost Views Viewmodel to handle the Event.
I Attached a sample to show the Effect.
As you can see there the Undo Button is enabled as soon as you start Typing in the Editor.
Regards
Thomas Stüven
DissableXamNumericInputUndoRedo.zip
