1160
how to bind Images with name in XAMComboEditor?
We want to add multiple Images with name in XAMComboEditor.
Like: ImageName- Image as kind of that.
Can u please help us, how we can add multiple images in combo box. We are following MVVM pattern.
Your help would be appreciate.
Thanks.
  • 6365
    Hello Kanwar,
    In order to display images inside the XamComboEditor for every item, I can suggest you create a BitmapImage type property for every DataItem in the ViewModel class and by using the ItemTemplate property of the editor, you will be able to bind for it.
    For example:
    <ig:XamComboEditor.ItemTemplate>
        <DataTemplate>
            <Grid Height="60">
                <Grid.ColumnDefinitions>
                    <ColumnDefinition Width="80" />
                    <ColumnDefinition Width="Auto" />
                </Grid.ColumnDefinitions>
                <TextBlock Text="{Binding Path=Name}" Margin="2" Grid.Column="0"
                            VerticalAlignment="Center" />
                <TextBlock Text="{Binding Path=Id}" Margin="2" Grid.Column="1"
                <Image Source="{Binding Path=Image}" Margin="2" Width="50" Height="50"
                        Stretch="Uniform" Grid.Column="2"  />
                <Image Source="{Binding Path=SecondImage}" Margin="2" Width="50" Height="50"
                        Stretch="Uniform" Grid.Column="3" />
            </Grid>
        </DataTemplate>
    </ig:XamComboEditor.ItemTemplate>
    Depending on the behavior you would like to achieve, you can always alter the DataItem class and adjust it accordingly. For more detailed information on this approach, you can take a look at the "xamComboEditor > Display > Using DataTemplates in Combo Editor" sample from our WPF Samples Browser.
    I have attached a sample application that demonstrates the approach from above.
    If you have any questions, please let me know.
    XamComboEditor_sample.zip
