I have a template column that has 3 values, when the value is "A", the cell should not be editable. If not, the cell should display the editor template which is a combobbox dropdown. How do I do this?
Thanks!
Hello Erika Bumatay,
I have investigated your issue that you need to implement conditional editing on a template column whose editor template is a combbox.
As to how to use a combo box in an editor template, it is explained in the following online help document.https://ko.infragistics.com/help/wpf/xamgrid-using-editing-events-to-create-a-custom-editor
And regarding conditional editing, use CellEnteringEditMode event and cancel the event.
private void xamGrid1_CellEnteringEditMode(object sender, Infragistics.Controls.Grids.BeginEditingCellEventArgs e){ if(e.Cell.Column.Key == "<column_key>") { if(e.Cell.Value.ToString() == "A") { e.Cancel = true; } }}
I hope this will help you.
Best Regards,
Noriko I.Developer Support EngineerInfragistics, Inc.
