125
How to remove Top-Level XamDataTreeNode through XamDataGrid without data source deletion
I'm now inter-working XamDataGrid and XamDataTree using same data source.
When level changes level of non top-level node to another level through XamDataGrid, It's very well moved.
But, when level changes top-level node to another level through XamDataGrid, That node remains TOP-LEVEL of tree and same shape (= same data) is placed where suitable place.
So, I remove that top-level-node in programmatically when level changes top-level-node through (XamDataTree object).Nodes.Remove(), That data has unusable..
How to remove top-level node through other controls (or programmatically)......
  • 2155
    Hello Hyung Soo,
    If XamDataTree's ItemsSource is bound to a data source, removing a node means removing the corresponding data from the data source.
    You are not able to remove a node but keep the data in the data source.
    I have attached a sample that demonstrates removing a top-level node from XamDataTree programmatically.
    Let me know if I may be of further assistance.
    Thank you,
    Mihoko Kamiishi
    XamDataTree_Sample.zip
